How do you tilt a universal ceiling mount??
J
Jackboy12
Hi, Ive recently bought a projector which came with a universal celing mount (looks like this UNIVERSAL PROFESSIONAL PROJECTOR CEILING MOUNT BRACKET | eBay UK)
I'm putting it up in a log cabin which has a slightly pitched roof. Does anyone know how you tilt these? Is it just via the slightly raised edge of the mount base? Would anyone have an instruction booklet?
Thanks in advance................
hi, the bracket has a gimble at the bottom. should have a nut on the bottom to loosen or tighten, make sure its tight but able to move, attach the pj and then just move to position and it should hold.
baz
J
Jackboy12
Thanks Baz, Is the gimble (I'm loving that word by the way!) on the projector end of the bracket?
I'll take a good look at it later on.
Thanks again.
