how do you tell if speakers are compatible with AV recievers?
Discussion in 'AV Receivers & Amplifiers' started by west, Jul 3, 2005.
  1. west
    west
    how do you tell if speakers are compatible with AV recievers? I have five 6 ohm satelites & an active sub how can I know if these are compatible with a particular amp or not? i'm far from decieded on an amp but would a Yamaha RXV450 work with my sony 6 ohm speakers & would have any trouble with the Sub too?
    Thanks for any help :thumbsup:
  2. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,111
    Southampton
    +260
    Check you user instructions to see whether the amp can drive speakers with a 6 ohm impedence.
    If you hav'nt got the instruction manual to hand, you might find more info on your kit HERE.
  3. west
    west
    thanks but what exactly should I be looking for?
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,082
    +96
    The speakers should not present an electrical compatibility problem for your amp unless they are some esoteric design.
  5. Passingbat
    Passingbat
    Feb 20, 2003
    7,569
    UK
    +1,331
    There is a setting in the Yamaha receivers for 6 ohm speakers. This is the link to the manual for the 457 ---- page 12 of the manual (not the PDF) in this link:
    http://www.yamaha-uk.com/pdf/owner_manuals/RX-V457.pdf
    the 450 is probably the same --- you could do a search for the 450 manual on the yamaha site. Don't know about the sub
  6. west
    west
    Cheers guys!
