How do you set the Philips 963SA & Sanyo Z1 to play 4:3 letter box ???
Discussion in 'Projectors, Screens & Video Processors' started by AVJ, Jul 25, 2004.
  1. AVJ
    AVJ
    Dear all AVForums Friends !
    How do you set the Philips 963SA & Sanyo Z1 to play 4:3 letter box in correct aspect ratio ???
    The only way I found can achieve the correct aspect ratio is :-
    (1) Philips 963SA set the TV output to 16:9
    (2) Use the "zoom" mode in the Sanyo Z1
    Don't know whether there is any better way to setup the 963SA and/or Z1 to achieve a better picture quality ?
    (i.e. I think using the "zoom" function in the Z1 may soften the picture a bit !?)
    Looking for any advice & thanks !!!
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    You are always better off having the DVD player set to "wide" or 16:9 and adjusting the projector aspect ratio so I reckon you have it set correct.
    Jeff
