How do you set the Philips 963SA & Sanyo Z1 to play 4:3 letter box ???
Discussion in 'Blu-ray & DVD Players & Recorders' started by AVJ, Jul 25, 2004.
  1. AVJ
    AVJ
    Dear all AVForums Friends !
    How do you set the Philips 963SA & Sanyo Z1 to play 4:3 letter box in correct aspect ratio ???
    The only way I found can achieve the correct aspect ratio is :-
    (1) Philips 963SA set the TV output to 16:9
    (2) Use the "zoom" mode in the Sanyo Z1
    Don't know whether there is any better way to setup the 963SA and/or Z1 to achieve a better picture quality ?
    (i.e. I think using the "zoom" function in the Z1 may soften the picture a bit !?)
    Looking for any advice & thanks !!!
  2. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    On my Sanyo PLV 30, theres a setting in the menu for screen size. This might be omitted on a true 16:9 pj.
