How do you Remove Stains On Varnish?
Discussion in 'General Chat' started by Garrett, Apr 25, 2005.
  1. Garrett
    Garrett
    Apr 21, 2001
    40,813
    2
    167
    The best thief you’ll never see.
    +6,890
    Does anyone know how to get rid of stains on varnish?
    I have a bottle of glass cleanser on my computer desk and when I picked it up there was a stain left behind. It has not lifted the varnish but the stain seems impossible to remove.
    I tried a bit of metal polish to take a thin layer off, but that does not work. Any body got any ideas without rubbing it down to the wood and re-varnishing?
  2. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Try using toothpaste. I've used it on real wood applications before and it has removed coffee rings etc.
  3. Dr Diversity
    Dr Diversity
    Try, with care, very fine wirewool. Toothpaste looks a better option though. Try in an area you can't see first.
  4. Garrett
    Garrett
    Apr 21, 2001
    40,813
    2
    167
    +6,890
    Its still there with toothpaste, I'm wondering if the stuff has reacted with the cleaner.
  5. mjn
    mjn
    May 24, 2001
    22,259
    Herts, England
    +10,112
    According to Nuts magazine....
    "Spread mayonnaise over the ring, then rub it clean with a dry cloth"
    Just as when you experiment with hamsters, i accept no responsibility for the outcome.
