How do you record a radio programme on Sky+
Discussion in 'Sky Digital TV Forum' started by jimcarney, Jun 19, 2005.
  1. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    I tried to record U2 tonight it would not let me ! Any Ideas?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    How would it not let you?
    If it didn't accept the programming after pressing "r" or when you entered the data after setting up a manual recording then perhaps it was blocked or just had corrupted EPG data which has been known to block recordings.
  3. Bluevanman
    Bluevanman
    To record a radio station you have to set up a manual recording. Press services and then 6.
  4. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Hi guys ,I tried to record on auto no go & could not enter the times of start & finish on manual, just would not work !
  5. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Not sure why not.
    Enter the manual record menu or press "R" while the radio channel you want is on screen.
    Put in the EPG number (if not present), select the day and then enter start/stop times then ADD the recording. If you look in the Planner it will then be there:)
