Quantcast
How do you mount a plasma to a wall
Katie1988
Hi hope this is in the right place.
I'm looking at putting a 50 inch plasma on a solid wall.
Iv had a look around and can pick one up fairly cheap.
My questions are when the bracket is on the wall how does the plasma secure to it?
I have noticed on the back there are bolt holes do I need to purchase some bolts seperate or do they come with the brackets normally?
Also what ways are there to hide the wires? Without ripping out the plaster.
I don't know much about this thing so wanted to make sure
Thanks Kate x
Insanity202
There's typically 2 metal strips that screw into the back of the tv, then there is a part that you attach to the wall. The tv will either hang or slide onto the wall fixture.
If in doubt get someone in to do the job. Might cost a little but it means the tv won't fall down.
If you look at John Lewis there's a very good wall cable tidy. Item number 89825012. Would link to it but Im on my phone.
reddevil74
Katie1988
Hiya again
ok so that's how it works, will get someone I know to do it there's is still on the wall!
that cable thing looks good thanks for that its out of stock though
Thanks for your continued help babe x
Katie1988
thanks red devil.
Looking through my TVs Manual it said the tv needs to be 100mm from the wall erm will most brackets be at least that?
I don't need a fire lol
65 inch plasma wow bet that amazing with films.
reddevil74
thanks red devil.
Don't worry it will be fine
You can't really make it out but there is some white trunking hidden behind the speaker containing all the wires to tv
Insanity202
Hiya again
Happy to help.
@Red
Your beast looks mint mate. It still doing you proud?
reddevil74
Happy to help.
@Red
Hi Insanity
Yes still going strong, moved house recently,added some new monitor audio apex to the front and just waiting on my custom build cabinet to be finished then that's me sorted for the foreseeable future :)
Insanity202
Hi Insanity
Look forward to the final pics mate. :)
reddevil74
Bracket view showing gap
reddevil74
Looks great do like the lights!
Are they part if the tv? Never seen it before.
It's a 5m led strip that can be bought on amazon,eBay etc
I got mine from visual chillout
reddevil74
Oh right cool.
Can you dimmer them? Change colour ect will take a look later on
Yeah you can adjust brightness and pretty much make any colour you want.
reddevil74
Brilliant looks very stylish
do you put them on all 4 sides or just top and bottom?
The strip comes with a sticky back side so you just stick around the perimeter of the tv. A 5m strip goes right around a 65 inch tv with some to spare
reddevil74
Ha did you put that on purpose or is it just me!
Take it you support united then?
That was just you! Lol
Yeah I'm a united man - all change this year
Katie1988
I'm a QPR fan lol someone's got to
Just been watching soccer special on sky sports news we won 2 nil
I come form a football mad family
Is Rooney going lol
Katie1988
Don't know if you saw my thread yesterday about having image retention problems
But if I have sky sports on for half an hour the logos are still there for days after its really annoying
Only had the tv for a while.
insanity said to take it back think I might!
reddevil74
Is Rooney going lol
Yeah he's in the departure lounge sitting beside Suarez and Bale!
Prob get told off for taking this way off topic now lol
Katie1988
Ha well probably get kicked off.
back on course where can I find one of those tv stands you've got had a look on Argos nothing there
where did you get yours from?
don't wanna spend more than 150 ish
Yours looks very expensive mind you!
reddevil74
I think it's discontinued now but it is one of these:
Alphason ABR1100-B TV Stands
I'm actually waiting on one I designed to be made for me by a local joiner
http://www.avforums.com/forums/av-stands-cabinets-seating-furniture/1785170-custom-build-av-unit.html
Katie1988
Similar to the one I found.
So your going with a light oak finish, that will look neat.
Have you got your quote?
Similar threads
Trending threads
Latest News
Kef Reference Series gets new finish and additional model
  • By Andy Bassett
  • Published
Naim announces native Qobuz support for its streaming hardware
  • By Andy Bassett
  • Published
Disney+ generates $100M in mobile app spending since launch
  • By Andy Bassett
  • Published
Bang & Olufsen announces Beoplay E8 3rd generation wireless earphones
  • By Andy Bassett
  • Published
