How do you make the HD5 stop after an album?
Discussion in 'Headphones, Earphones & Portable Music' started by sxc, Jun 20, 2005.
  1. sxc
    sxc
    Jun 5, 2005
    56
    +4
    When playing an album on the HD5, it seems to just continue onto the next album at the end of the one you selected. If you have "Units on" it repeats the album.
    Does anyone know how to make it just stop playing at the end of an album, or at the end of a "unit"?
  2. martynb
    martynb
    Jan 31, 2005
    ......it doesn't help you much, but i have a similar problem with my HD3, and posted this issue some months ago.
    I never found a resolution, and will have the machine looked at by Sony when I send it back to them under the HD3 recall for the directional keypad issue.
    Martyn.
  3. myepitome
    myepitome
    Don't you just go into album and press play on the album you want...if you are pressing play on the artist then it will play the albums of that artist but if you just want the album then go into the album list and select that album
    Hope that helps
