How do you load games on xbox hd
Discussion in 'Xbox Forums' started by leedsfireman, Aug 4, 2003.
  1. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,191
    38
    +3
    I have a chipped xbox but when i try to load games on hd a get a message saying " your modchip does not support the eject on reset trick found. Disc must already be inserted to install."
    I have the x-pro chip, any idea's?
    Andy
  2. phenom2003
    phenom2003
    You will need to change the bios (if possible) with an X2 or similar bios which supports the eject trick. check www.worldxbox.co.uk for more help.
