How do you know if your Pioneer 757Ai is a Pal progressive version or not
Discussion in 'Blu-ray & DVD Players & Recorders' started by danny daniell, Nov 8, 2004.
  1. danny daniell
    danny daniell
    Jul 25, 2004
    1,708
    2
    +171
    Can anyone tell me how you can tell a Pal progressive 757Ai from just a normal Ntsc prog model?
    Thanks for your help,
    Dan
  2. Smurfin
    Smurfin
    Aug 13, 2002
    21,442
    +4,386
    Just what I was about to ask:D
  3. inzaman
    inzaman
    Dec 16, 2002
    7,972
    Derby
    +1,043
    I dont know how to tell from a technical viewpoint, but mine is ntsc progressive only and when i am watching a ntsc dvd in interlaced mode and press the progressive button the picture breaks up before going back to a normal picture, i.e as the relevant scaler takes over (either pj or dvd player), when a pal dvd is being played and i press this button nothing happens, as the picture is still interlaced as there is no pal progressive functionality.
    Therefore using the above theory if your picture breaks up on both pal and ntsc when in interlaced mode after you press the progressive button then it will be sending a progressive signal, if nothing happens then not. Well thats the theory :)
  4. danny daniell
    danny daniell
    Jul 25, 2004
    1,708
    2
    +171
    Thanks for that inzaman (with looks like that you should be in the movies! :D ;) )will try that method later.Is there anyone out there who HAS a PAL progressive 757Ai?. If so,does it blatently say so in your manual?
    inzaman,does it say Progressive scan on the casework of your player ? many thanks, Dan
  5. recruit
    recruit
    Dan i have the Pal 757 i know it works as it just does :rolleyes: on my plasma it gives 480p & 576p that is how i know but also when it came it had a sticker on the front saying PAL/NTSC Progressive Scan.
    I will try and find my manual but i think it is in the loft so will have to be tommorow.
    John
  6. danny daniell
    danny daniell
    Jul 25, 2004
    1,708
    2
    +171
    John,you are a diamond :smashin:
    Cheers mate,Dan
  7. awhb
    awhb
    I have quite an early 757Ai (March '03) which didn't have PAL progressive (I had it upgraded by Sequoia last year :) ). I've just checked the manual and there is nothing in there to say that it doesn't (didn't!) support PAL progressive scan.
    I believe that when the 757 started to, it had a sticker on front. However, I don't know if they still bother with that on the more recent models.
    Adam.
  8. recruit
    recruit
    Agree with the above, Dan i have checked the manual and there is notheing to say whether it Displays 480/576p :( it just states that thru component it will display a progressive signal.
    John
  9. astirling
    astirling
    Oct 1, 2004
    1,955
    113
    Dunfermline
    +700
    I got mine about four weeks ago and it has this sticker.
  10. Smurfin
    Smurfin
    Aug 13, 2002
    21,442
    +4,386
    astirling, as it looks like I may have to buy this new, can I ask where you got yours from and how much did it cost?
  11. V5-APS
    V5-APS
    May 7, 2001
    681
    London
    +15
    Is it not just a case of upgrading the firmware to a later release ????
    Might be worth giving Sequoia a call :)
