D
Deleted member 507786
As above. Thanks.
I am pretty sure it does, see here:The Pioneer SC-81 does not have multi channel analogue inputs, so you won't be able to connect the Oppo using that method. HDMI would be the best available connection.
Although if you are only concerned with a stereo analogue connection you could use a pair of RCA leads from the front right and front left audio out of the Oppo into a spare stereo analogue audio input of the Pioneer (eg CD in).
I think I've got it now - many thanks.Ah, the SC-LX81. As you just said the Pioneer 81, I looked at the Pioneer SC-81 here:
https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/SC-81_OperatingInstructions041414.pdf
If your receiver is the SC-LX81, then the multi channel inputs are labelled front, center, surround, and surround back, then you have left and right for each of those, plus the subwoofer:
http://img15.hostingpics.net/pics/50927120151104143436.jpg
The Oppo 203 multi channel oututs are labelled, front left, front right, centre, surround left, surround right, surround back left, surround back right and subwoofer. So, just connect the corresponding output to the corresponding input:
OPPO Digital - Ultra HD Blu-ray Disc Players - Buy Direct from the Manufacturer
Yes, you would need to select the analog multi channel in input on the Pioneer, I am not familiar with that AVR, if it isn't available as a standard input you may have to assign it in the main menu.Should it say multi channel in on the amp?
Yep, that's what I've done. Cheers. The sound is not bad compared to HDMI bitstream, there is quite a lot of power there, just not quite up to HDMI bitstream. I think I will leave the cables in and play about with it from time to time. Cheers again. Annoying trying to get those cables in the right inputs took me 4 or 5 attempts! Sound was coming out of each speaker though. Cheers!Yes, you would need to select the analog multi channel in input on the Pioneer, I am not familiar with that AVR, if it isn't available as a standard input you may have to assign it in the main menu.
