How do you get sky+ to output in 5.1
Discussion in 'Sky Digital TV Forum' started by Oves, Aug 17, 2004.
  1. Oves
    Oves
    Jan 17, 2004
    5
    I've got a Sky+ box and using a Sony DAVSC5 all-in-1 theatre system. When I watching a movie broadcast 5.1 I'm not getting this through my speakers. I've got an optical cable between the Sky+ and the DAVS player, but still the same.
    Has anybody else come across this, or found a solution :smashin:
  2. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    Need to set the sky setup to output Dobly digital in menu -> system setings, -> sound settings -> dolby D. That should work.
    Rds Steve
  3. Oves
    Oves
    Jan 17, 2004
    5
    Thanks Steve, sorry I should have mentioned that I've already tried that.
  4. Ian182
    Ian182
    Oct 15, 2002
    912
    46
    Leeds, West Yorkshire.
    +99
    Have you checked the settings on your Sony ?
    It may need to be set to "auto" or something similar (I've not got a Sony so I don't know........) to correctly decode the 5.1 signal - otherwise it might be playing it back in stereo or Pro Logic..........
    Worth a try anyway.
    Ian.
  5. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    i know it sounds obvious but there are only some movies etc. in dolby digital..............only mentioned this because i was in that boat!
