how do you get itunes on ipod?
Discussion in 'Headphones, Earphones & Portable Music' started by apple beez, Nov 27, 2004.
Tags:
  1. apple beez
    apple beez
    how do you get itunes on a ipod? :confused:
  2. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
  3. apple beez
    apple beez
    ok how do you get music on ur i pod
  4. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    You use iTunes.
    Is it trick question night or something ?
  5. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    Ah .. just seen your question on the other thread.
    Yes - you just plug your iPod into the computer (after you've installed iTunes). iTunes will spot that you've connected an iPod - first time it will offer to 'sync' with it. After that it's just automatic.
  6. apple beez
    apple beez
    the process of getting itunes on ipod is??????
  7. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,000
    48
    Reading, Berkshire
    +54
    the ipod doesn't run itunes, you run itunes on the PC you want to connect to the iPod.
  8. Radiohead
    Radiohead
    Dec 24, 2001
    4,295
    Amazingstoke
    +433
    Here's a suggestion that's so wacky it might just work:
    Try reading the manual.
