How do you get depth in photos?
Discussion in 'Photography Forums' started by snerkler, Aug 7, 2013.
  1. snerkler
    snerkler
    Jun 18, 2011
    21,120
    +11,831
    I'm not talking about DOF but depth of the picture/subject. I see other people's pictures and they almost look 3 dimensional, as though you can put your hand into the picture, whereas my pictures look flat. So how do you take pictures so they show depth?
  2. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
  3. snerkler
    snerkler
    Jun 18, 2011
    21,120
    +11,831
    Thanks. When you say fast, do you mean wide aperture? So FF create better 'pop' than APS-C?
    Thanks for the link :smashin:
  4. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Yes, IMO they do, crop owners sometimes argue this point by saying they can use a longer lens etc etc bla bla bla. All I know is after owning many crops, they definitely dont create the same pop as my FF cameras.
    Yeah fast lenses = wide aperture.
  5. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    I think you said you had a 300mm lens, try at 300mm Im guessing its a 5.6, that will isolate your subject more, problem with doing it this way is distance from subject when framing. You can also get closer to your subject with your 16-50 at 50mm 2.8 and it should give some nice shallow dof.
  6. snerkler
    snerkler
    Jun 18, 2011
    21,120
    +11,831
    Thanks for your help. I can create shallow DOF quite well, but I just don't seem to get that great 3D look/feel that I've seen. I appreciate that you say FF can get this better than APS-C, but I have seen some great depth/3D look with APS-C's such as the Canon 7D.
    Obviously I just need to keep practising, but I just wondered if there was some 'magic' way to achieve it. I guess there's a lot of factors, with lighting being an all important one?
  7. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    Then wack up the clarity slider in lightroom to increase microcontrast. Not too much though as that will create a blooming/glow around things.
  8. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Yeah, this is good advice. Some lenses offer much better contrast than others eg. my Nikon 70-200 was better than my Sigma and images did pop a bit better because of it, even though they were the same FL at same apertures.
  9. snerkler
    snerkler
    Jun 18, 2011
    21,120
    +11,831
    Wow, that's definitely more of the look I was meaning, thanks :smashin:
    Is there a way that you can create that in the actual photo (or at least to some degree) or is it always done post production?
  10. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Lenses, get spending.
  11. snerkler
    snerkler
    Jun 18, 2011
    21,120
    +11,831
    :laugh:
    Is there a specification or description that will guide you on this, or is it just a case of the more expensive the lens the more it will do this?
    I thought I'd got a pretty decent lens with my SOny 16-50mm f2.8 tbh.
  12. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    The 16-50 is a very good kit lens. Get yourself a nice Zeiss 24-70.
  13. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    How about this? there's supposed to be a special '3d look' about zeiss lenses.. that I try to capture sometimes.. I'm not sure if I've ever done it - this might be close?
    [​IMG]
    IMG_0250 by dancook1982, on Flickr
    another one I was trying for 3d...
    [​IMG]
    IMG_4897 by dancook1982, on Flickr
  14. snerkler
    snerkler
    Jun 18, 2011
    21,120
    +11,831
    Yep, that's more the look, although that is a bit 'miniature' looking imo. Is that all Zeiss lenses, or particular ones such as primes?
  15. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Look at the EXIF, its shot at F1.4 on a FF camera thats something like F0.95 on a cropper, Dans blurred the foreground and background with the middle being in focus creating the effect.
  16. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    MAYBE what you want is this then? @1.2 (canon not zeiss)
    [​IMG]
    IMG_4324 by dancook1982, on Flickr
    Using a wide aperture to blur the foreground and background to capture an subject in between?
  17. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    ... Nice, you still manual focusing that lens?
  18. snerkler
    snerkler
    Jun 18, 2011
    21,120
    +11,831
    Yep, definitely getting there :smashin: One thing I've found is that if I'm using small f-numbers part of the face is in focus and some not, I guess I'm getting too close then if you can use an aperture this wide and still get the full face and body in focus.
    I'm learning so much it's great :clap:
  19. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    Thankfully not :smashin: the CZ is MF only, but I did some microfocus adjustment and the 1.2 is working great.
    yup, closer you get the smaller the depth of field.
  20. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    A lot of it is to do with how much microcontrast they can capture. Primes will normally be better than zooms.
    spend at least a few months working on your composition and technique before you start getting carried away with buying exotic lenses. The 16-50mm is a good lens and capable of great results.
  21. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Glad to hear, really want one but cant justify at the moment, have to spend money on other things, boo.
  22. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    All my money's going on my wedding this month :thumbsup:
  23. DolbyDan
    DolbyDan
    Sep 17, 2006
    2,103
    Canvey Island
    +265
    Yep it's the micro-contrast and how lenses render the transition of the DOF. Zeiss and Leica prime lenses render DOF like no others. Professional Canon & Nikon tele-prime lenses also render nicely (not Zeiss like though), but have micro-contrast like no others. Fortunately there are a few gems out there that do it too. A lens that has low chromatic aberrations whilst sharp at a lowish aperture normally equates to very good micro-contrast. My 85mmF1.8G is one of them, but doesn't have the rendering of the Leica's or Zeiss', which is why the Zeiss 100mmF2 is high on my wish list, once (if ever) my mate wants his Sigma 105mmF2.8D back.
  24. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    Zeiss 100 F2, drool.
  25. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    There is a new Zeiss 135mm f2 that I was starting to like .. really a shame I can't have fast AF with that though.
  26. snerkler
    snerkler
    Jun 18, 2011
    21,120
    +11,831
    Thanks for the feedback guys, much appreciated. I won't be going out buying any new lenses just yet, but good to know that I can get the look I want if and when I ever get good enough.
    Thanks DolbyDan for explaining what to look for in a lens to get the microcontrast :smashin:
  27. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Bright colours work well too
    [​IMG]
  28. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Sony 85mm 2.8 can be had for £100 ish SH
    [​IMG]
    [​IMG]
  29. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Sigma 105mm 2.8 OS HSM is beautiful but expensive, lucky I picked one up S/H as new for great price :)
    [​IMG]
    [​IMG]
  30. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Sorry btw I like portraits if you hadn't already guessed ;)
