How do you get best Sky+ PQ?
Discussion in 'Plasma TVs Forum' started by steve 111, May 16, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Have decided on getting the Panny PWD6. My biggest concern is picture quality on Sky+, especially as I watch a lot of sport.
    Which is the best way to connect Sky + to the plasma, based on the following options:-
    RGB Scart > RGB Scart terminal board
    RGB Scart > Component terminal board using JS RGB>Component convertor
    RGB Scart > VGA Slot using JS RGB>VGA convertor
    S-Video > Component terminal board using Amp to upconvert signal
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    I would recommend the RGB Scart > VGA input using a JS Tech converter. :smoke:
    Steve
  3. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    The RGB to Component converter is superb for connecting Sky +, but gives a slightly softer picture than the RGB to Plasma VGA unit. The slightly softer picture can be advantageous as it does filter some noise from Sky, but for the absolute best picture then it has to be the RGB to Plasma VGA unit.
    All the best,
    Dr John Sim.
