How do you do the flicker tweak on the AE700?
Discussion in 'Projectors, Screens & Video Processors' started by Nikumba, Oct 16, 2004.
  1. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    Nikumba
  2. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    From the menu select and hold down Options for about 5 seconds and then you will see a service menu which offer access to Flicker where you can adjust the flicker using the left and right cursor buttons. It's easy to do and really does make a difference.
  3. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    I dont seem to have an Options button on the remote or on the pj
    Nikumba
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Nikumba,
    "Options" is not a button, it's on the list in the main menu... you highlight the "Options" on the main menu by pressing the Down arrow on the remote control, when it's highlighted, hold down the "menu" button on the remote control for a couple of seconds and the on screen menu will change to the Service menu, where you can access the flicker tweak.
    S.
  5. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    That didnt work, when i hold the menu button down the menu closes
    Any ideas?
    Nikumba
  6. P0rkCh0p
    P0rkCh0p
    Oct 8, 2004
    12
    From turning the projector on;
    Press MENU.
    Highlight OPTION and press ENTER.
    Highlight OSD and hold ENTER on the remote for approx 5 seconds.
    The 'Service Menu' (Ext Option) will appear.
    Scroll down to FLICKER ADJ and press ENTER.
    Use Left and Right on the remote to adjust the flicker value.
    :smashin:
  7. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    That worked cheers p0rkCh0p
  8. pj
    pj
    Mar 15, 2002
    2,441
    117
    w.mids
    +507
    is it just me or do the settings seem to change on every power up? i.e flicker adjust needs adjusting everytime for each input?
  9. begu
    begu
    Oct 5, 2004
    16
    3
    +4
    Let the PJ warm up. I have to wait for about up to 2 hours, before the settings really level. But of course it's quick to adjust, just pause the movie and adjust (for example at the startup, 0.5h, 1h, 2h). After 2h there is no need to adjust anymore.
    It has something to do with the temperature of the panels, optical block etc.
  10. Beano
    Beano
    What about the VB tweak ?
    How can that be done ?
  11. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    5,001
    Lockerbie, Scotland
    +916
    I can see why this has to be done at specific intervals. However do you have to go through this procedure every time you use the 700 or is it a one off task. Also do you have to do it for all inputs that you will be using, or does the one tweak cover all the inputs ( Scart, Composite, VGA etc.. ) ?
    I have my 700 and will be going down this path shortly after it is mounted and the screen arrives. During the demo though I have to say I never saw any VB to the degree shown in pics here and even when I thought I could I was unsure even then.
    Ta.
    Keith Hurst
