how do you connect sky+ to a pc to record the programmes on to dvd?
Discussion in 'Blu-ray & DVD Players & Recorders' started by phoTToniq, Oct 29, 2004.
  1. phoTToniq
    phoTToniq
    Can you connect Sky+ to a PC to use the writer in the PC to burn DVD's?
    Basically I want to archive some Sky+ content without having to buy a standalone dvd writer. What is the best quality way to make this connection? Is there an all digital way?
    Dubcat
  2. redmax
    redmax
    Sep 13, 2002
    1,079
    ESSEX, UK
    +43
    I am in the same situation and would also like to know if its possible to archive from Sky + direct to a PC DVD burner.
    Anyone have some advice if this is possible?
    :lease:
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    Guys,
    I would recommend seeking advice on the Home Cinema PCs forum. Some of the chaps on there do this and they are best placed to advice on the best kit for the job.
