How do you check hours on a Panny PW6?
Discussion in 'Plasma TVs Forum' started by Smurfin, Oct 26, 2004.
  1. Smurfin
    Smurfin
    Aug 13, 2002
    21,443
    +4,386
    Could anyone tell me please?
  2. cmorrison
    cmorrison
    i was in the same boat last week. think u press the volume down button on the plasma and the button below the power button on the remote 3 times.
    man that's a lot of buttons in one sentence.! :eek:
    pretty crap reply but at least its better than
    "why dont u search for it?"
    :hiya:
  3. Smurfin
    Smurfin
    Aug 13, 2002
    21,443
    +4,386
    Many thanks:)
  4. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Smurfin did it work?
  5. Smurfin
    Smurfin
    Aug 13, 2002
    21,443
    +4,386
    Yes, more specific instructions are:
    Hold down the volume button on the plasma itself (not the remote like I first tried).
    On the remote, while holding the plasmas volume button, press the button beneath the power button 3 times. Then select "SD" from the menu, and it'll show you how many times your plasma's been switched on vs hours.
    I've had mine now for around 5 months, surprised it only has 250 hours on it:eek:
  6. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Im at work at the moment so can't try this but does anyone know if it's the same for the PW7?
    cheers
  7. novaya_zemla
    novaya_zemla
    Or you could have tried the search since the question was only asked (again) a few days ago.....
  8. cmorrison
    cmorrison
    was waiting on that!! ;)
    Some people eh! :suicide:
    they just can't help themselves
  9. Tony8377
    Tony8377
    Aug 19, 2004
    954
    Essex
    +4
    It is the same for the PW7 - mine already has 210 hours on it and only had it for a month. Think I need to get out more :suicide:
  10. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Thank you tony.
  11. blu-tac man
    blu-tac man
    Sep 18, 2004
    27
    3
    Does this work for the Viera too?
    blu-tac
  12. Tony8377
    Tony8377
    Aug 19, 2004
    954
    Essex
    +4
    Try this (but don't blame me if it breaks your plasma as I just copied it from another website).
    Accessing the Service Menu on Consumer Models :
    ( Consumer "PA" , "PD25" & "PX" Models Only )
    Set sleep timer to 30 minutes
    Go to cable / antenna input and switch to channel 124
    Turn volume all the way down with the remote
    Press down volume button on the unit itself
    CHK will appear in red in the top-left corner.
    Press the power button on the remote control to get into the service menu
    with "CHK" displayed.
    Press power on the unit itself to exit the service menu
    (turns off the unit but doesn't erase your user mode settings
    See following for loads of info on Panny Plasmas:
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=407154
