How do you calibrate your display for Sky HD?
T
Tommy Angelo
At the moment I'm just finding dark parts of movies and trying to pull as much detail from the blacks as I can without loosing black level or crushing whites. Does anyone else have a better way to calibrate a display for Sky HD?
mray
The way I did it was to record one of the Star Wars movies, then play it back alongside the dvd version and try to match up the brightness and contrast.
there may be easier ways, but that's one of the ways I did it, as well as the method you used.
SmokeyBubbles
Established Member
Calibrated mine using the THX calibration tool on some DVD’s i.e. Star Wars, most Disney titles etc. Was very pleased with the results.:D
SmokeyBubbles
Established Member
It's well hidden!
From memory I think it was in the set-up page. At first you cannot see it but by moving the buttons sideways it becomes visible. Sorry can't be more exact but was a while ago! Trust me it is there somewhere:rolleyes:
It is basically a series of screens that allows you to set brightness, contrast etc. and there is also an audio calibration tool for both stereo and Dolby 5.1 surround sound.
mad_matt
Established Member
I used the DVE dvd, includes how to setup surround sound as well. Found it very easy to use and imho the pq on my plas is pretty damn good.
Mike Groves
Established Member
I'm talking about calibrating for Sky HD, not for a DVD player.
Have your setup ISF calibrated - you pay for it (around £200 if I remember) - but if you want the best from the plasma its well worth it. The method calibrates all the inputs (HDMI, component, Scart, etc), not just the one being used for Sky.
ChrisOH
Established Member
The question is how to callibrate for Sky HD and the problem is the same as how to callibrate for Sky SD.
As there are no test patterns broadcast (afaik) for either platform you can only guess or approximate. Tarbat, using a 1080i output from a PC is doing an approximation but this misses a point as video black is set differently in HD to SD, so simply sending HD resolutions does not overcome the problem, unless you use HD video test patterns.
What we really need is good old test patterns to be broadcast so we can use these to set our displays.
John
There are test patterns , you just have not looked hard enough :D
There are occasional Colour Bars broadcast , I have yet to find a greyscale though . I have posted a couple of times over the years on where they are , a quick search should reveal all :smashin:
Neil Davidson
AVForums Sponsor
Hi Guys,
On the Sky+ units, the correct contrast setting was Low. On the Sky HD boxes the correct setting seems to be Medium.
To calibrate the Sky input on the display the pros use a calibrated pattern generator which allows the display to be set to the correct reference levels. From there you can use a couple of tricks to get the brightness and contrast set correctly and typically you back down the colour to accomodate the red push the boxes tend to have.
Once this is done you have a bang on greyscale and all user controls set to the correct points.
Unfortunately most of the test patterns that I have seen have been noticeably off in certain areas and the worst thing you can do is calibrate to an inaccurate reference.
HTH
Neil
breadbun
Established Member
I had my contrast settings on LOW as recommended somewhere on this forum. However, the picture was noticeably darker in general than my other sources (Freeview, XBox360, etc), so I have recently put it up to MEDIUM and it seems to make a big difference.
Tarbat
I use these - http://www.w6rz.net/ and others, and also used the test patterns from my Lumagen HDP, although I no longer use the Lumagen.
And yes, testing with a 1080i over HDMI from a PC is only a close approximation to SkyHD calibration, but is about the best we can do without a decent test transmission from Sky or BBC - see http://www.avforums.com/forums/showpost.php?p=3466229&postcount=2
ChrisOH
Established Member
Showing my ignorance of Sky HD (I use DVB-S for BBC atm) sorry if I misslead about test patterns, my experience is based on standard Sky + where there are none at the moment (afaik)
I didn't mean to be critical Tarbat just qualify what you'd said.
Chris
🎬 Poirot 3, Spider-Verse, Psycho Collection & Mask of Phantasm 4K + best/worst animated Batman
Back
