How do you add R2 prog scan to Denon 2800?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Neal, Jan 21, 2002.
  1. Neal
    Neal
    How can you add progressive scan to the Denon 2800 so it can handle Region 2 DVDs as well as Region 1?
  2. Noman
    Noman
    Check this link, read the instructions carefully. (You have to put the file on a blank cd-r)
    If you have the 5250 firmware you might have to "downgrade" to original 5248 before loading the modified firmware.
  3. Noman
    Noman
  4. Neal
    Neal
    Unfortunately the directions are in German. What do you do with the bank30.rom once you have downlaoaded. You burn a disc, place it in the player and...
  5. Noman
    Noman
    - Insert CD -- updates are up-played automatically - device goes into
    standby modus
    - Take out the CD and close the drawer
    - Press at the same time the keys "Skip-Rev" & "Pause" & "Open/close" -
    display shows "Initialize"
    - Switch off the main power
    - Press at the same time & hold keys "Play" & "Open/close"
    - Switch on device at the main power
    - Press 2x "Menu" on the remote control, version number in the display
    should be shown
    - Power off
    - Update is finished
    DO NOT USE THE REMOTE CONTROL DURING THE PROCESS!!!!!!
    Next time you need help with translation try http://babelfish.altavista.com/
