How do/would you organise...
Discussion in 'Headphones, Earphones & Portable Music' started by MitsiTurbo, Jan 23, 2005.
  1. MitsiTurbo
    MitsiTurbo
    Jan 6, 2005
    940
    28
    Milton Keynes
    +82
    ...a large mp3 collection?? The reason I am asking, is my slimp3 server is in a right mess. Can never find songs that I am looking for! Am going to sort them out properly and then do all the ID3 tags aswell. I currently have them organised in directories by genre (apart from ripped albums which have their own directory. I am thinking of giving each artist a directory and organising that way.
    Your thoughts on a postcard please! :rolleyes:
    Many Thanks
  2. captaindobie
    captaindobie
    Apr 17, 2002
    580
    Scotland
    +18
    I give each artist it's own folder and then a sub folder for each album/single by that artist. I have upwards of 8000 tracks on my PC (and counting) but everything thus far is quick and easy to locate...
  3. Sandman
    Sandman
    Nov 28, 2002
    3,187
    Glasgow
    +730
    I also have a folder for each artist and then a sub-folder for each album easy to oganise and find what youa re looking for. The only problem is I needed to create an artist folder called various for compilations.
  4. Zef
    Zef
    Apr 24, 2002
    221
    Hertfordshire
    +9
    Itunes can do that - you select the tracks you want as a compliation and edit the tags - there is a tick box to say compliations - when you let Itunes manage your folders it creates a folder call compilations and a seperate folder according to the album name under that.
  5. p3rfect
    p3rfect
    Oct 12, 2004
    16
    What ever you do don't let Windows Media Player's Libary sort your collection for you! I once did and within seconds my entire music collection was in pieces. Always make a backup first if you use any automated software!!
    I do all mine by hand now, like the guys above:
    Main Music dir, 25 dirs labelled A - Z, a dir per Artist, then a dir per Album
    i.e. \Music\C\Coldplay\Rush of Blood to the Head\[mp3's in here]
    I use Tag & Rename (latest) to look up the tags from Amazon, make sure they are all ok and correct if necessary, and then rename them to [tracknumber].[albumname].mp3. The renaming is done to keep the name under 8 characters so they can also sit on my xBox. For each album I also grab the album art from Tag & Rename and rename it to folder.jpg, works well in windows explorer and the xBox. The album art should also appear within iTunes, which is what I use to view and play my mp3's and transfer to my iPod.
    Can't go wrong if you do it that way, just takes a while, but then I am anal so I don't care. I'm also very bored at work which explains why I've gone in to so much detail!!!
