how do make some component leads?
Discussion in 'Cables & Switches' started by cypher007, Jan 17, 2005.
  1. cypher007
    cypher007
    Jan 2, 2005
    415
    19
    +11
    can i just use sat cable? and some sheilded phono's?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Yep, SAT cable might be a bit stiff but it can be used. Basically any 75 Ohm cable and some phono (RCA) connectors will do the trick.
  3. Zone
    Zone
    Jun 24, 2001
    6,563
    Barnsley
    +2,179
    Just make sure its double screened, foil and copper braid.
    RG59/6 give great results and is very cheap, 50p a meter or so for RG59, and use metal screened plugs not the plastic ones, take care when soldering together and you’ll end up with some very nice capable cables.
  4. cypher007
    cypher007
    Jan 2, 2005
    415
    19
    +11
  5. Zone
    Zone
    Jun 24, 2001
    6,563
    Barnsley
    +2,179
    You pays your money you takes your choice.
    Benefit of diy is that you can make the cables any desired length you want.
    I actually use a Nikkai 10mtr S-Video lead for hooking up a $ky box and Xbox to my PJ with good results, so if you don’t want to go to the bother of making some homebrew leads then give em a go, if they’re no good take em back!
  6. mince bigalow
    mince bigalow
    guys can I get 75 ohm connectors from maplin at all? If not where could I get some from?
  7. Zone
    Zone
    Jun 24, 2001
    6,563
    Barnsley
    +2,179
    BNC yes.
    RCA no, they simply don’t exist, I believe the Canares that Mark Grant uses on his cables come close, though you need special crimp tools to attach them to the cable.
  8. mince bigalow
    mince bigalow
    Oh, OK. So any half decent phonos will be as good as any average cable I can buy from the likes of QED, Thor etc?
    Thanks for the help :)
  9. rowey7777
    rowey7777
    I have been looking for some cables myself and can't seem to find any advertised over 10 m. Is there a problem with doing longer runs.I need about 12 -15 m
    Does the pic degrade over this length
  10. Zone
    Zone
    Jun 24, 2001
    6,563
    Barnsley
    +2,179
    One of the forum sponsors Tv Cables have a 15mtr cable, no idea what the quality will be like but for £15.99 worth a punt, alternatively diy.
  11. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    You can solder the centre pin (if you have and can use a decent iron) and you can crimp the ferrule with a normal uninsulated balde crimper by doing multiple light crimps around the circumference.
  12. Zone
    Zone
    Jun 24, 2001
    6,563
    Barnsley
    +2,179
    I'll take your word for it having never used the Canares.
