How do I use Powerstrip to get 24p - Samsung a656/8800gts 512/XP
seriousc
I'm trying to change the refresh rate to 24hz or a multiple of that to get smooth playback. The problem is I'm not sure what to change in Powerstrip (mainly about the frequencies and what not)
If anybody has the advanced timings for 1920x1080 @ 24,48 or 72 I'd appreciate it.
Thanks.
lmaolmao
timings are different for every setup, so what works for one may not for the other.
when i was running my projector through vga, the timings changed one day for no reason (it may have been drivers or other software).
so its down to you to find the timings.
with the power strip tray icon right click then "display profiles" -> "configure"
then click this:
http://www.imagebam.com/image/0c04fd15212740
and you can edit the frequency here (1), and you can do smaller adjustments with (2):
http://www.imagebam.com/image/9bb4a715212842
have a play about, see what you come up with.
8800gts, i have read, somewhere, that they dont work with powerstrip, so if any of the above dont work, unfortunately thats why.
CES 2023 Round Up: New TV Lineups for 2023 from LG, Samsung, Panasonic, Hisense & TCL
