How do i use my SPL?
Discussion in 'Home Cinema Speakers' started by JIT, Dec 24, 2003.
  1. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    My SPL has just arrived but what is the best way to use it?
    I have the range set to 70dB with response at slow and C weighting.
    Do i point it at each speaker as i play the setup tones or point at the TV screen as the tones move to each speaker in turn?
  2. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    Just read AV FAQ which has a good description.
    Which are the best tones to use -
    AV Amp
    AVIA
    Video Essentials
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    Best tones are probably those on a disc, which one i guess doesnt matter
    As far as how to point it...... well set it up where your head would be, then leave it there and balance the levels the same on all channels
    ad
  4. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    how much did the spl cost m8
  5. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
  6. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    Id advise that analogue is a generally better one to get..... digital devices are universally more difficult for measurement
    ad
  7. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    i have a pio 912 with macc do i really need one of these or has the macc done it well enough
  8. Montana
    Montana
    May 24, 2003
    194
    Crawley , West Sussex , England
    Jelly if you listen to a film soundtrack or something that is SACD or DVD-A and you think everything seems ok , it normally is.But a SPL meter is normally a good investment, and tweaking you're system manually normally gives that little bit better smoothness to the soundstage.As it has with my VSX-D2011-S.
    Andy
