how do I use my av fronts for hi fi
Discussion in 'Home Cinema Speakers' started by fifa, Apr 19, 2004.
  1. fifa
    fifa
    Feb 2, 2004
    2,929
    71
    middlsex
    +67
    hi guys can anyone tell me is it possible to use my 601s that I use for my av fronts, also with a hi fi amp How would I wire them? thanks
  2. The Hemulen
    The Hemulen
    Dec 5, 2002
    549
    Cambridge, UK
    +19
    I presume you have a higher quality stereo amp than your AV amp by your question.
    In that case (and assuming your AV amp has pre amp outputs) why not leave your main speakers connected to the stereo amp and drive a spare line input on that amp from the AV L&R outputs when you are watching films.
    You will need to set up your speaker levels with the stereo amp at a known volume level. Best way to do this is to leave the AV L&R level settings the same as your centre then match the left and right channels to the centre with the stereo amp volume. Then either note or mark the amp where this 'calibrated' level is and always leave it at this when using the AV.
  3. fifa
    fifa
    Feb 2, 2004
    2,929
    71
    middlsex
    +67
    OH thanks posh I will give it a go
  4. Stevo99
    Stevo99
    Feb 13, 2002
    2,046
    +65
    fifa - ive been trying to send you a PM but you inbox is constantly full
    I have your delivery number from ROyal mail for cable
  5. fifa
    fifa
    Feb 2, 2004
    2,929
    71
    middlsex
    +67
    hi craig well I finally got the cable today friday thanks
  6. Barend
    Barend
    Apr 12, 2004
    804
    +9
    This is possible but not ideal- there will be tonal and phase differences with the rest of the channels.
    I face the same problem, maybe I'll try relays.
    Barend
  7. fifa
    fifa
    Feb 2, 2004
    2,929
    71
    middlsex
    +67
    oh ok barend I thought there might be some kind of switching avalable to allow this to be done
