How do I unlock my DVD Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by Galaxyblue, Dec 30, 2003.
  1. Galaxyblue
    Galaxyblue
    Dec 30, 2003
    46
    Essex
    So it becomes region free?
    Thanks in advance
    GB xxx :confused:
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    It depends on what type it is.
    Some makes allow you to press a sequence of remote control keys.
    Some require modification which you can't do yourself (at least, not without some help).
    The website www.dvdrhelp.com offers some hacks for those that are hackable.
    The trader www.dvdchips.co.uk may be able to offer help if it is not hackable by you.
  3. Galaxyblue
    Galaxyblue
    Dec 30, 2003
    46
    Essex
    Hi Nigel, and thanks for replying. It is a Mustek and I got it from www.autdirect.co.uk it came with surround sound etc.
    It has been unlocked before, my mum did it, but I suppose when we disconnected it to move rooms it lost the code.
    She said she just typed a code into the remote control but she can't remember.
    This posts makes me sound really young - 'My Mum' LOL - I'm 26!!!!
  4. tonyb
    tonyb
    May 14, 2003
    96
    Kent
    Hi galaxyblue,
    Here's a link to a number of hacks for mustek players link
    Hopefully your model will be listed there. If you can't find anything, just try a search in google or something along the lines of 'mustek zzz dvd hacks'. Just replace zzz with the model number of your player.
    Tony
  5. Galaxyblue
    Galaxyblue
    Dec 30, 2003
    46
    Essex
    Thanks Tonyb - you are a sweetheart
    GB xxx
  6. Galaxyblue
    Galaxyblue
    Dec 30, 2003
    46
    Essex
    Ok, Have had a look at that site, and my player isn't on there.
    It is a V561 5C any advice gratefully received
    Thanks xxx
  7. Solar
    Solar
    Dec 2, 2003
    2,557
    Earth
    +463
    hopefully this should work
    works only with empty tray
    press setup on remote
    now press on panel fast:
    next
    prev
    next
    prev
    now you can see the version number
    make your choice: ver.255 for codefree
    and at last setup on remote
    give that a try, if not ill look for some more
