al shookup
- Joined
- Oct 26, 2006
- Messages
- 243
- Reaction score
- 1
- Points
- 127
I have an old hp laptop with an 80gb hard drive and xp op system.I tried to upgrade from xp to windows 7 using a disc but have ended up with both operating systems installed I assume as the hard drive is showing as having 55gb in use. Is there a simple way to remove the xp element from the system please?
As is pretty obvious, I know very little about such matters and if you have any advice, please spell it out in simple English so I can understand the procedure needed.
thanks for any help.
