How do I turn on SVid output??please help
Discussion in 'Desktop & Laptop Computers Forum' started by newstuart, Aug 6, 2004.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    Ive got a Advent media center pc with a Nvida graphics card and svga + svid outputs, I know I have to turn the svid output on via a menu but cant work out how to do it.my local PC world (where i bought it) are worse than useless and have know idea.I have done it before but have had my pc wiped due to a virus and cant remember how i did it any advice ??
  2. SimonInd
    SimonInd
    May 9, 2001
    209
    London
    You'll need to have something connected to the S-video output when you power on the machine so that the card can detect it. Then goto right-click on the desktop and go to Display, Properties, Advanced, nVidia XXXXX. The nvidia dialog should include a menu option for something like 'Multiple displays', from which you should be able to select clone mode to turn on the S-video display.
    Hope this gets you going?
    Simon
