How do I turn off mod chip for xbox live?
Discussion in 'Xbox Forums' started by Triggaaar, Dec 21, 2004.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    I know each mod is different (I think some have manual switches, others swith chip off when you open dvd etc).
    Mine is a xenium chip (through premodded.com). There isn't a manual switch.
    It has an LED, which I thought indicated whether the mod was on or not, but when playing a game from the HD (therefore mod on I assume) the LED can be either Red or Green, depending on whether I booted into avalaunch or evox.
    The 'original bios' option from the start up menu fails to load, with the message 'Your xbox requires service. Please call customer support'.
    EDIT - this bit has been sorted, thanks to an increadibly quick reply frpm premodded. The HD wasn't locked, and it has to be in order to go into the original bios.
    I can go into the Microsoft Dashboard (and therefore live) via evox, but I don't know whether the chip is still enabled (not sure if this gives an indication, but the system reboots if I press both triggers, black, and the back button).
    Any ideas
    Thanks!
  2. smokingreen
    smokingreen
    Apr 23, 2004
    680
    Derby
    +15
    Hia, the only way you can go into evox/avalaunch is if the chip is on and you have booted from a hacked bios. If you then load a game from evox/avalaunch and go on live you will be banned. Also as you suggested, if the reboot works (two triggers back button and start) then a hacked bios is loaded and you cannot use live.
    You must find a way to either turn the mod off so that the xbox boots from the bios on the motherboard or boot from a retail bios that is stored on the chip/mod. Without a disc in the dvd drive either of these methods will only load the MS dash.
    I dont know what bios you have at the moment, but I strongly recomend X2983 as this bios is live safe - it will not let you connect to live when it is loaded.
  3. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    hole the on button for 3 secends i think it is
  4. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Thanks guys. My 'original bios' option is the way forward for me. I can only load it with the hard drive locked, and once there, the controller reboot doesn't work.
    I didn't realise, but I guess this means I can't play NTSC disks on live. The only NTSC disk I have is KOTOR 2 (not a live game anyway), but with video set to NTSC, I can't load it from the original bios. I would have bought US versions of Halo 2 etc, but I get the impression I wouldn't be able to go live with them.
