how do i transfer xbox saved games on to a memory card?
Discussion in 'Xbox Forums' started by zamwessell, Feb 27, 2005.
  1. zamwessell
    zamwessell
    Jan 2, 2003
    1,236
    +136
    how do i transfer xbox saved games on to a memory card and then on to another xbox?
    I have looked through and tried all the options i can and still have not seen any options to do this.
    Do you have to have the specific game running and transfer via the game options.
    I was under the impression that it could be done using the Microsoft dashboard...am i wrong?
    Thanks.
  2. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,963
    2
    2
    Manchester
    +4,475
    Yes, its done through the dashboard. Go to the Main Menu => Memory => Xbox Hard Disk, then scroll down to the saved game you want, then select the save to the right of the big symbol. If you just select the big symbol, it will just give you the option to delete, if you select one of the smaller symbols, you can copy or delete. Be aware that not all saved games can be copied (to stop cheating).
  3. zamwessell
    zamwessell
    Jan 2, 2003
    1,236
    +136
    big thanks pal
  4. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    so that's how you do it - had one for ages and never found a way of doing it - doh!
