How do I test my len's IS (OS) is working?
Discussion in 'Photography Forums' started by Furq, Jan 31, 2009.
  1. Furq
    Furq
    Feb 20, 2005
    320
    +15
    I have the Optical Stabilizer on my Sigma 18-20mm f3.5/6.3 switched on... but I'm not convinced it's working.
    I'm getting some blurry shots, and I've never seen the image 'jump' in the viewfinder (or heard a small noise), like a Canon with IS.
    How can I test the OS is working?
  2. Throttle
    Throttle
    Sep 28, 2004
    1,839
    Leigh
    +109
    Try taking a photo handheld with it turned on and then another without it turned on but all the rest of the settings the same then compare both photos.
  3. Jas H
    Jas H
    Feb 1, 2007
    907
    28
    West Malling
    +59
    I only have Canon lenses with IS, but when I switch it on, I can see the image in the viewfinder becomes noticeably more stable. It's very apparent.
  4. Jonny1973
    Jonny1973
    On Canon's you can usually hear the motor whirring if you hold it up to your ear.
