How do I store movies on my Hard drive
Discussion in 'Computer Components' started by (GTV)Chris, May 30, 2004.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    HI
    I would like to store movies on 2 large HD's in my HCPC.
    I know your'e not supposed to do this, but I own the DVD's anyway so it's nothing FACT should be worried about.
    What is the easiest software for this and how many movies could I cram on a 160gig HD?
    Many thanks
    Chris
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,490
    South Derbyshire
    +199
    You are not allowed to store movies on your HD.
    But... use DVDshrink and you could get about 35 films (uncompressed) onto a 160gb HD.
    DVDshrink will allow you to get rid of trailers/adverts and other language tracks. So all you get is the movie.
  3. Taz
    Taz
  4. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Cheers fella's.
  5. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    DVD decrypter works very quickly....
    BUT.....
    I can't play the file back smoothly?
    It jerks about, skips great chunks etc.
    I have a decent setup
    80gig HD Maxtor 7200
    Athlon 2600 XP
    Win XP
    512mb ram
    Geforce 3 graphics card
    Any idea's?
    Ta
    Chris
  6. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,490
    South Derbyshire
    +199
    Do you want help?
    You must tell people what you are using for playback.
    And what settings you used for DVDdecrypter.
    Having never used DVDdecrypter I cant help you with that one.
    I found DVDshrink so easy that I havent bothered with anything else.
  7. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    DVDdecrypter just simply saved the info and VOB files to my HD.
    I used powerDVD to play back as per Spectre's recommendation.
    I can't give much more info than that.
    I will have a go at DVD shrink to see if there are any improvements.
    Chris
  8. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Discovered it was powerDVD.
    It is totally knackered!! It no longer plays any of my discs??
    Error code 80040216 cannot find file??
    Anyway I will try a new fresh install and see how that goes.
    Ta
    Chris
