How do I split Sky+ signal to 2x TV's
Discussion in 'Sky Digital TV Forum' started by peanutnboo, Feb 12, 2009.
  1. peanutnboo
    peanutnboo
    Aug 2, 2008
    119
    +3
    I have Sky+ in my kitchen
    How can I watch seperate channels in 2 rooms simultaneously ?
    Can I use an old sky box and run a spare cable from the quad LMB ?
  2. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    No...but you could if you run the spare cable from the LNB :devil:
  3. peanutnboo
    peanutnboo
    Aug 2, 2008
    119
    +3
    thanks for your reply JayCee . So I'd need to run a spare cable from the LMB to my old sky box yes ? then I would be able to use the old remote to control the old sky box and view one channel from my Sky+ ?
    Would I still be able to pause and record one channel on the Sky+ box ?
  4. squishyfishy
    squishyfishy
    Sep 1, 2008
    60
    11
    Renfrew
    Just buy a quad LNB.
    That way you get what you want. No sacrifice of recording.
  5. peanutnboo
    peanutnboo
    Aug 2, 2008
    119
    +3
    I thought I had a quad LMB is the standard SKY+ just a double then yes?
    How exactly would using a quad work with 2x tv's ?
  6. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    To be able to watch different subscription channels in different rooms at the same time you need Sky Multiroom .
    This requires another card from Sky which will get the same channels as the main card and costs £9.75/month with both boxes connected to the same phone line at all times.
    If you want to watch only the free channels on the second box then no extra subscription is needed (or phone line connection) but you may consider getting a freesatfromsky card (£19.57 one time payment from Sky) which will ensure the correct BBC1/ITV1 regions, C4 and FIVE on the EPG and enable Sky3/Setanta Sports News etc.
    To feed the extra receiver simply take a lead from any spare outlet on the quad LNB.
    The outputs on the LNB are independent of each other and your Sky+ box will function exactly as it always has
  7. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    Doesn't the fact that three different people have told you that it is an LNB (Low Noise Block detector) give you any hint that you might be calling it by the wrong name?
  8. peanutnboo
    peanutnboo
    Aug 2, 2008
    119
    +3
    thank you Fernandez for taking the time and trouble to explain all that in simple straighforward language that even beginners like me can understand without being patronising or rude like broadz :smashin:
    Its members like you that make this forum the one of the best around
  9. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
  10. peanutnboo
    peanutnboo
    Aug 2, 2008
    119
    +3
    yo Fernandez
    youda man :thumbsup:
    bought some cable connected to LNB and spare sat box switched on and zipadeedoda.....20 minutes and Mrs peanut is happy watching the 6 Nations in the lounge and I can watch and record something else in the kitchen ....Bliss :clap:
    I think you may have saved our marriage well at least my sanity anyway:D thanks
