How do i show what pc spec
Discussion in 'General Chat' started by raigraphixs, May 19, 2005.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    51,152
    +15,997
    I need to check the spec (detailed) on a pc in my workplace, how do i know if it is multi processor?.
    I use a mac, and could not find the eqvilant setting to show a detailed spec for pc apart from the properties; general hardware tab?.
    ta
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Rip the lid off :) Seriously it's unlikely to be multi processor (statistically speaking) depending on your work environment. The obvious reply is if it's a branded PC, check their website!
  3. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    Right click on the taskbar at the bottom of the screen and choose "Task Manager". Click on the "Performance" tab. If there is more than one CPU, there will be a CPU Usage display for each processor. If there is only one CPU usage display there is one processor.
  4. Dr Diversity
    Dr Diversity
    Hold down the Windows key and press 'Print Screen', that'll give you some info
    Alternatively search for dxdiag.exe in the system or system32 folder. Run that, some odds & ends in there
  5. raigraphixs
    raigraphixs
    Jul 11, 2001
    51,152
    +15,997
    We have 2 new servers for our hi-end print work (creo).
    OK, 'show graph per cpu', shows 4 little windows. I think we have 4 processers in each server, would that be right, i think the engineer said 4 running at about 3.2 gzh each processor the other day, i was not sure,
    But there is no detailed spec about the processors, is this possible?.
    Our IT guy is back monday, he can check it.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    How about installing a system evaluator and running that? If you get hold of Everest it will show you every bit of information that it's possible to find about the machines.
  7. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    If it's showing 4 individual graphs, it's pretty certain that there are 4 processors in there.
    You should be able to run MS System Information if it's installed which will give a bit more detail:
    Start|Programs|Accessories|System Tools|System Information
