how do i set my desktop to 1080i with the panny ae700?
Discussion in 'TVs' started by ian2k3, Jul 14, 2005.
  1. ian2k3
    ian2k3
    im currently using 720p for my desktop, so it upscales my dvds to that resolution, but of course my true hi def films look better in 720p
    what refresh rate do i need to set my desktop to for 1080i. i use powerstrip to make custom resolutions.
    thanks
  2. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    Your desktop should be set to 1280x720 as that is the native resolution on your PJ (this is called pixel mapping 1:1). Any 1080i hi def material will be automatically rescalled by your PJ.
  3. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    Err - if you are running with a permanent Windows desktop of 1280x720 and 1:1 mapping - then surely the 1080i material will be scaled by the PC not the projector?
    In other words if the PC is permanently outputting 720p - then 1080i stuff replayed on the PC will need to be scaled by the PC
    (PJ wasn't a typo for PC was it?)
  4. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    Err sorry :oops: yeah!
  5. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    Is there any benefit to running your desktop at 1080i??
  6. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    If you are running your PC into a 1080i display - like an HDTV CRT display (direct view or projector) - then a 1080i output from a Windows PC would allow you to replay 1080i video with no scaling and in full resolution (so would improve over a 720p PC output being scaled by the display). However 1080i won't make Windows look very nice - as individual pixels will flicker at frame (not field) frequency - which isn't nice.
    If you have a 720p native display then running your PC in 720p makes a lot of sense.
  7. razorlight
    razorlight
    What video card are you using and what drivers. I am having lots of problems with the nvidia drivers.
  8. ian2k3
    ian2k3
    its a radeon 9800 pro with the latest ati catalyst drivers, i downloaded a 1080i land of the dead trailer and it didnt look that different to 720p
  9. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
    It should'nt. 1080i is an interlaced picture whereas 720P is progressive. The 2 different formats are about the same quality! There are many threads discussing which is the better format.
  10. ian2k3
    ian2k3
    i just put MAME on in 1920,1080 and it looked no different to 1280,720.
  11. DEANO-B
    DEANO-B
    Oct 15, 2004
    514
    Leeds
