How do I rip DVD audio
Discussion in 'Desktop & Laptop Computers Forum' started by (GTV)Chris, Jun 25, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    695
    Manchester
    HI
    I need to use sound bites from a movie on DVD. So I suppose I need them to end up as WAV files.
    How the heck do I end up with WAV files from a DVD sound source?
    Chris
  2. TEK
    TEK
    You could use DVD Decryper or SmartStripper to rip the specific AC3 stream to your computer. You may even be able to rip straight to WAV (it's been a while) but from the stream you can use any number of little tools to manipulate or convert further to a desired format. Check out http://www.dvdrhelp.com/tools AC3Tool springs to mind
