Pbryanw
Established Member
I got sent a CD of jpg pictures by an old aquaintance recently. Took it out of the case and must have applied too much pressure as the CD cracked. The crack is just one line aboout a mm in width from the center of the CD to the edge of the CD. It appears on both sides of the CD.
I daren't put it in my CD-ROM case just in case it breaks the drive. Anyway is there some way to fix it or recover the information on it which isn't too expensive. The pictures on it are sentimental so I'd like to get them back if possible.
Val
Val
