How do i remove Outlook Express from my PC?
Discussion in 'Desktop & Laptop Computers Forum' started by Barney_Tabasco, Oct 19, 2004.
  1. Barney_Tabasco
    Barney_Tabasco
    Feb 5, 2001
    623
    Sheffield
    I now have Outlook and want to remove Express as it has some kind of glitch in it. I have looked in Add/Remove programs and then in Microsoft Office but it only lists Outlook not Express!?!?
    Can anyone help?
  2. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Without a bit of know how, you can't......Hence the reason for the Dodge case and other things MS are being taken to court over.
  3. Barney_Tabasco
    Barney_Tabasco
    Feb 5, 2001
    623
    Sheffield
    Ah, i see one of those is it?
    Well i think i have a virus on it so have transferred all my emails over to Outlook. The problem is the virus is stopping me from deleting emails from Express so i'm stuck with this application holding Megs worth of files taking up unnecessary room!
  4. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,334
    Don't uninstall Outlook Express as Outlook won't work if you do - I know, I learned the hard way a few years ago !
  5. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    I thought you could uninstall Outlook express just by going to add/remove programs, then going to add/remove windows components, NOT the default add/remove programs window.
  6. yulsa
    yulsa
  7. yulsa
    yulsa
  8. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    M8 try this this software CLICK ME THIS should do you fine m8 :smashin:
