How Do I Remove Motor Noise
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by koimad, Aug 5, 2002.
  1. koimad
    koimad
    I recently purchased a cannon mv5imc digital camcorder. The only problem I have with it is that the internal microphone picks up the tape head motor noise. Can any one point me in the direction of how I can remove this noise, I've tried the remove wind noise filter and this does not work.
  2. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,122
    Leicester
    +51
    External mike,if it's got a hot shoe adapter.
  3. Drafter
    Drafter
    Your camcorder requires a SA-1 Adapter Bracket or equivalent and a wired mic. this will fix the noise problem but somewhat offsets the size advantage. I use the Sima Video Bracket (Model SVB-1) with an extension bar to clear the LCD screen. This bracket has 2 accessory shoes ie mic & light.
    Drafter
