How do I remote control my PC?
Discussion in 'Desktop & Laptop Computers Forum' started by bigfatsi, Apr 15, 2005.
  1. bigfatsi
    bigfatsi
    Jan 24, 2005
    120
    19
    Teesside
    I have been using my Plasma as a screen for my PC for a while to play big screen games, playing DivX movies etc and have left the DVD player to take care of the DVD's. However the DVD player is so completely crap (toshiba 240E) that I have started to look into playing them through the PC too. I have got TheaterTek, FFdShow and Dscale and have been playing with them and am quite impressed with the results but to integrate the PC in properly I want to be able to remote control it as I do everything else. I have a sunwave 3000 multi remote that should work fine, but on the PC side I have no idea. I have an IR receiver that I use for my old phone to send receive data etc, can I use this as a receiver for the remote? If so what software do I need. If not what do I need to make it work? :lease:
  2. Skunkpipe
    Skunkpipe
    I'm not sure about using your current IR reciever etc.
    A really simlpe solution that might be worth considering though is the ATI Wonder Remote - this has an RF reciever that plugs into the USB. the remote can also control the mouse. Before MCE came along I used one of these with Showshifter.
    The
    ATI Wonder costs about £20
  3. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,274
    The gyration mouse is really good too, a usb receiver is connected to the pc, the mouse sits on a recharging base, and you can use it up to 25 feet away. You can also wave it in the air or operate it on a surface like a normal mouse.
    You can get a matching keyboard also.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I use both a Remote Wonder and Gyration keyboard & mouse .. the ATI is cheap the Gyration not. :) The Gyration mouse is incredily easy to use, if slightly 'odd' in that you literally wave it about in the air! (it can be used conventionally too).
    I use the ATI to control TT.
    If you want an IR solution then I have the iMon Inside (it came with the PC case), the remote itself is pretty average but of course a learning remote can capture the codes .. the 'inside' version of the iMon support remote power-up, which isn't supported by all IR modules for PCs.
  5. mahkum
    mahkum
    This remote supports MCE 2005 as well. It is available in a slightly different guise here
  6. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    You can buy IR receivers which connect to your com port for about £6, they connect to your system with a program called Girder. There is also a TheaterTek plugin for Girder. All you need is a suitable remote. I use a spare code on a Kameleon 6in1.
  7. bigfatsi
    bigfatsi
    Jan 24, 2005
    120
    19
    Teesside
    That's what I want to hear!!
    I've just installed Theatertek so it would seem the best and cheapest option for me right now. Any idea where I'd get one from?
  8. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    The ATI Wonder sounds interesting, do you assign mouse and keyboard buttons to the control or is it controlled via TT software, do you know if this would work with Zoomplayer.
  9. zoidy
    zoidy
    Mar 18, 2005
    693
    Surrey
    +53
  10. jpfrost
    jpfrost
    Jan 18, 2003
    93
    Could you suggest somewhere to buy the IR receiver for £6.
  11. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    Have a look in the Girder site forum, someone will be making them. I'd make my own, not much to one really.
  12. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    I could do with the IR reciever as well to enable me to use my ne Logitech Harmony remote with my pc when it arrives.Anyone found one yet?
  13. TheAvalanche
    TheAvalanche
    I need one also...
  14. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    and me!
  15. stlic
    stlic
    Feb 17, 2004
    762
    +19
    You can pick up premade IR recievers from eBay pretty cheaply. I bought a serial version from this chap and it works flawlessly with my Harmony remote. You can also ask him to extend the lenght if needed (I went for a 3m lead), delivery was fast. There is also an alternative available; 1m but looks a little more solid with a nice plastic sheath.
  16. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    Just bought one.
    Thanks.:thumbsup:
  17. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    Or make your own for less than the cost of a sandwich.
    Found this, if you can solder.
  18. bigfatsi
    bigfatsi
    Jan 24, 2005
    120
    19
    Teesside
    I've ordered from the second one. Cheers! I've heard that Girder is a real nightmare to configure so I'm looking forward to loads of fun!!!
  19. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
    IRMAN ... Its all you need
    http://www.intolect.com/
    Bought one about 3 years ago, never needed anything else. Works well with girder, and other programs.
  20. jpfrost
    jpfrost
    Jan 18, 2003
    93
  21. mahkum
    mahkum
    jpfrost - That remote is the same as the one being sold here. I downloaded the software from Niveous and it works perfectly.
  22. gingerjumper
    gingerjumper
    I have the ATI wonder remote but cannot get it to work with winamp or windows media player for skipping/rewinding/playing/pausing music. Does anyone know if it's possible to configure it?
    If not, can anyone recommend a remote that would allow this functionality?
    cheers
    gj
  23. pRot3us
    pRot3us
    Oct 20, 2004
    6,360
    +4,475
    It has mouse cursor controls and buttons programmed onto it as standard, there are plugins for many popular programs that you can download for it to work with TT,Zoomplayer,etc. also with the Remote Wonder Key Factory plugin you can program custom keypresses/hotkey settings to any of the buttons :smashin:
    yep it works with both media player and winamp
    download remote wonder plugins here ;)
