How do I read Sony error codes? (KD32DX200)
Discussion in 'General TV Discussions Forum' started by IanK, Aug 24, 2005.
  1. IanK
    IanK
    Oct 19, 2002
    42
    My Sony KD32DX200 is begining to go faulty. When first powered up after 8 hours or so off, it displays a broken picture for a few minutes. Sometimes it switches itself off and the power light flashes 4 slow red flashes. What does this mean?
    After a few mins of being powered up the set operates fine. Is there any fault memory I can interogate once it's behaving ok?
    Thanks,
    Ian
  2. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    I don't know the answers to your question but have you tried contacting Sony about this? I would have thought that whatever the problem turns out to be it's going to take a service engineer to fix it, if it's giving you a flashing error code.
  3. ventoboy1000
    ventoboy1000
    Hi IanK,
    The TV will have logged the error in service mode(Under Errors/Faults) but as TV Headache has said, a service enginner will most likely be needed to fix the problem.
    I too have this same TV and I think its a superb set. Hopefully yours can be fixed as Sony don't make this model anymore.
    Is your TV still under warranty ?
    Vento
  4. IanK
    IanK
    Oct 19, 2002
    42
    Hi Vento,
    Thanks for the reply & the reply to my other post on how to access the service menu to read the error log! The set is just over 13 months old and was a replacement for a KD32DX100 that had scrolling bars problems on the AV inputs. This set was checked by Sony Technical before sending out! I can't believe it's gone faulty too!
    I've contacted Sony, but no reply as yet.
    Cheers,
    Ian
