how do I post sketchup of my ideas for scrutiny?
subterracineman
I've done a sketchup (eventually) and would like to post on here for input.
Can someone please tell me how?
I've hunted through forums, but just keep getting lost or distracted
Many thanks :smashin:
Kevin
BlueWizard
I assume you mean Google SketchUP.
Load the file into SketchUp, then go to the [File] menu and select [Export]. Then select [2D Graphic]
This will bring up a Save window. In the file formats near the bottom, select .JPG and save the file. (Remember where you saved it.)
Then post this new JPG file as a link to a place like Image Shack.
It saves a pretty large image, so you may want to use a Image Editing Program to reduce the overall size. The image I Exported was 958 x 648 and 140k bytes.
I reduced this image by about 40%. Though how much you reduce it, if you do, will depend on the level of detail it contains.
Steve/bluewizard
