How do i play DVD-RW on my pc
Discussion in 'Blu-ray & DVD Players & Recorders' started by amidar, Jan 4, 2007.
  1. amidar
    amidar
    Mar 13, 2006
    5
    Just got a dvd recorder so i'm a bit new to this, i've recorded some tv programs to DVD-RW media, i can play the dvd in any of my dvd players but when i put it into my pc (Win Xp Sp2) windows reports the DVD as blank.
    I've had a search round and discovered this might be a known problem with Win XP, so i dowloaded the recomended hotfix for it and it still dosn't work.
    Anybody any experience of this or any ideas how to sort it. Thanks.
  2. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    You have finalised the disc on your DVD recorder first haven't you?
  3. concrete monkey
    concrete monkey
    Dec 31, 2006
    60
    yes u need to finalise the disk ....and if it still has a bit of trouble update the firmware of your pc's dvd drive!
  4. amidar
    amidar
    Mar 13, 2006
    5
    Thanks for the reply's. No i haven't finalised the disk i though if i finalised it i wouldn't be able to use it again.
  5. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    if you finalise the disc you can reformat (blank) it and add new stuff, but once formatted you can't add more to the disc. you could rip the material to the pc and reburn
    some players will play non finalised discs, but most need it finalised
  6. ChainsawDude
    ChainsawDude
    May 6, 2006
    375
    28
    Basingstoke
    +29
    Some recorders will unfinalise (an RW DVD) too, some wont.
  7. JayCee
    JayCee
    Jan 20, 2004
    23,619
    Lanarkshire
    +2,547
    I think you meant to say once finalised?
  8. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    yup!
  9. BrianF
    BrianF
    Oct 28, 2005
    222
    Not so. Some DVRs will unfinalise a DVD-RW so you can continue to use it as before.
  10. amidar
    amidar
    Mar 13, 2006
    5
    thanks for the help finalised the dvd and it works fine.
  11. zappo
    zappo
    Nov 7, 2005
    683
    +47
    I found that I was able to access disks that were not finalised by using Nero. You might want to do this if you are editing.
