How do i open my battery slot in my HD5?
Discussion in 'Headphones, Earphones & Portable Music' started by babs, Jul 30, 2005.
  1. babs
    babs
    Jul 30, 2005
    153
    16
    London
    Sorry if this is a stupid question, but i can't open my HD5 battery slot. It's got a little arrow pointing downwards so i try to slide it down but it is still stuck! How the hell do i open the damn thing??
    Any answers would be gladly appreciated. :)
  2. shadowritten
    shadowritten
    Insert a thin, pointy object into the little hole in the battery cover and then slide down - it will open easily!
  3. babs
    babs
    Jul 30, 2005
    153
    16
    London
    Cheers mate, will try out later.
