How do I make PVR w/ USB an Ethernet device
Discussion in 'Digital TV & Video Players & Recorders' started by cainej, Aug 23, 2005.
Tags:
  1. cainej
    cainej
    Is there a way for PVR with USB e.g. Topfield et al - to connect to an ethernet and appear as some computer device (shared drive?) that a PC on same network could then pull up the .mpeg and burn movies to DVD disc?
  2. Maff et1
    Maff et1
    In the case of the Topfield 5800 you can do this with a modified NSLU2 USB NAS adapter and some command line software: http://www.nslu2-linux.org/wiki/Puppy/HomePage - you should also have a look at the forums on www.toppy.org.uk for more info. Using the NSLU2 you can get a command line to control the toppy (a program called puppy) or create an FTP server for transferring to/from the PVR.
