How do I make my speakers move?
Discussion in 'Home Cinema Speakers' started by Sun, Aug 19, 2004.
  1. Sun
    Sun
    Oct 8, 2003
    787
    28
    Stowmarket, Suffolk
    +39
    Hallo,
    Funny question, or maybe just worded funny but how do I make the actually cones in my speakers move? I have some Wharfdale Diamond 8.1s, 8.3s and a matching centre, they're powered by a Yamaha HTR5640. When I have been for demos of other speakers before I have seen the cones bouncing in and out when driven especially with something fast like some good Drum&Bass, Roni Size kinda tempo.
    My speakers don't do that and tbh I think it looks quite cool :D Is there something I need to do or is it just dependant on speaker type?
  2. Daneel
    Daneel
    Dec 5, 2002
    2,833
    68
    London
    +8
    Put on something bass heavy and turn up the volume. I don't like to see them move much for fear of damage. Plus if that is happening on my speakers I'll be deaf fairly soon after.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    Have you switched on the cone bouncer in the Yamaha's setup menu ?
  4. Sun
    Sun
    Oct 8, 2003
    787
    28
    Stowmarket, Suffolk
    +39
    Well I've cranked it up to about -25 and It's ear splitting at that point and they don't seem to bounce too much, ah well, no point trying to wreck em I spose for the sake of looking cool. My sub takes most of the bass anyway so that might explain it a bit.
    Cone bounce, good idea, that's next to the "WAF: ON" option isn't it?
    Cheers guys :)
  5. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    OK, here's what you have to do. :thumbsup:
    Purchase a top notch CD Player and then some BIG Krell or equivilent 500W+ per channel amps. For Speakers try the PMC MB2's or the LINN KOMRI's. Put the whole lot together in one end of an aircraft hanger.
    Sitting just outside the door, use your remote to turn the volume up as loud as it will go and press play. If your Cerebrum survives the initial shock You should be able to see the speakers moving. :clap:
    Alternatively use the same equipment but with some B&W 601's You'll see them move! Just the once mind you! :)
    Have fun.
    Seriously if your speakers don't move when you turn them up then they're not ment to. All you will do is damage the drivers.
    Have fun!
  6. Solar
    Solar
    Dec 2, 2003
    2,549
    Earth
    +463
    i have had a few pairs of Wharfdale Diamond's and they have never moved with bass
    its just the way they are manufactured
    as nightshade said if they aint meant to DONT try to make them or they WILL die !
  7. bob1
    bob1
    Nov 7, 2002
    4,328
    Sheffield
    +131
    :rotfl:
  8. Killahertz
    Killahertz
    Ah!, just found the cone bounce control on my amp. Thought i'd give it a whirl, and just to prove it, video the effect - on the end of a JL 12W7:-
    http://www.osaid.dsl.pipex.com/ta/12w7.avi
    (right click and 'save as') ;)
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    if you have a mechanic friend borrow a timing strobe......
  10. bob1
    bob1
    Nov 7, 2002
    4,328
    Sheffield
    +131
  11. morksbeanbag
    morksbeanbag
    Jul 25, 2004
    723
    Chesterfield, Derbyshire.
    +49
    LMAO.
  12. bass007
    bass007
    Apr 8, 2004
    1,291
    london
    +35
    If you wanna see your cones Dancing then buy a Turntable, and a decent Phono stage and your cones should move with ease without turning the volume too loud.
  13. sm0akes
    sm0akes
    Jul 4, 2003
    Turn the bass controls up, and play something with a decent beat. My diamonds 7.1* dance around nicely :)
  14. rob_w
    rob_w
    Hahaha - you forgot to say buy a crap turntable. - no cone flap with my LP12 here, at very decent levels. Unless of course the disc is warped... :mad:
    Sun,
    If you really want to see your cones go stupid, just switch them to full range on your amp and play some bass heavy music. (Dr Dre, Prodigy, D n' B etc..)
    Or set them to full range, your sub to none with lfe re-directed to mains, and stick on some Nemo at reference level. :devil:
    Rob
    Can't see the point of it though. :confused:
  15. JiMbOb_74
    JiMbOb_74
    Wow I didnt notice my denon has a cone bounce enhancer also...
    WOW turned it on....and my speakers now look cool
    SOund rubbish though
    Does anyone know of any external cone bounce enhancers as the denons isnt 'boomin' enough.
  16. Swifttech
    Swifttech
  17. rob_w
    rob_w
    http://www.behringer.com/EX1200/index.cfm?lang=ENG
    :devil:
    Rob
