How do I make a sequence from a load of TIFF files?
Discussion in 'Desktop & Laptop Computers Forum' started by (GTV)Chris, May 31, 2004.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    As the title states.....
    How the pooing Norah do I do it??
    Ideally I want to get it onto DVD in the end.
    Ta
    Chris
  2. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    As in a slideshow or more of an animation?
    Powerpoint for the slideshow and flash for animation.
    Macromedia do (or used to at least) a 30day trial of flash.
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,190
    +1,231
    I can do this Chris in a variety of packages.
    AN avi at "best" quality of 720x576 is about 27M for the newer sting.
  4. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    I tried it in Premier but it took forever, then would't play back. Then I realised that I didn't know what the hell I was doing :)
    AVI is what I was trying to acheive.
    What I ultimately want is ofr TheaterTek to play the file before the main movie starts.
    Didn't want to put you to anymore trouble :D
    Chris
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,190
    +1,231
    I can render you 3 for the material and stick them on a cdr ( not sure if I kept the really old one actually).
    I might even get round to knocking out the totally cleaned up synthetic version one of these days.
    I'm a little unsure as to the quality issues when going to AVI . The 27m version I did was based on having all the quality settings maxed out and it is readable by mplayer so it should be a piece of cake as they say. ( this was in Shake and Combustion2 : Combustion2 rendered a lot quicker)
  6. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Ok, I will send them to you, well, I'm only really interested in the 28 second asteroid blue version. I seem to remember someone postin a really nice version but thought it may have been 4:3 ratio?
    Also, managed to load up some fab old ads into an Avid, there are also some really nice "No smoking" and "Please turn off your mobiles" type stings.
    I am trying to make quicktimes out of them but some of the files are too big to go onto a CD :(
    I'll get there eventually.
    Chris
