How do I make a photo CD?
Discussion in 'Desktop & Laptop Computers Forum' started by Timh, Jun 19, 2002.
  1. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +267
    HI
    I want to have some photo cd's made to show on my dvd player, a Toshiba sd-510, a friend has put some photo's on a cdr for me with Nero but I get a no disc error on the display of my dvd player.
    Should any perticuler software be used to make photo dc's? if so which one.
    Thanks for any help.
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Can your DVd player read CRD disc?
    If it can then is must have something to do with the way Nero sets up a photo CD. Myabe your DVD player can't read them.
    Have you tried the disk on your PC's CD rom drive?
  3. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +267
    Yes my dvd player will read cdr and cd-rw discs.
    :confused: the cdr disc is blank when I put it into my dvd rom drive on my pc, he also did me a copy on a cd-rw disc, this has the photos on it, but just the pics no slide show on the disc, I guess the pics must be written to the disc with some photo software, I will pop over to www.download.com to see whats available.
  4. brock_landers
    brock_landers
    May 2, 2001
    100
    lancashire
    Try ulead dvd pictureshow, it lets you select the pics, put menus in for different events and also select mp3s as backing tracks.
    It will then allow you to write the disc in vcd format.
    Results are very good indeed.
    Brock.
  5. KarlRobinson
    KarlRobinson
    Jan 8, 2002
    159
    16
    Bedford
    VCDEasy is a very good program that also supports Hi-Res VCD stills and anamorphic images. It has is own built in burning software and image conversion program. If your looking to just put all those digital camera shots on your tv I can think of no better program.
    If you after a menu driven system, use the original Philips VCD toolkit 2.0 it's old but very comprehensive and also supports hires stills.
    Programs like Video CD Creator/Ulead etc are good but don't support hires stills.
  6. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +267
    Thanks guys, thanks for the software tips, I will look into them, I have had some success, I had a video cd burnt with Nero, it worked fine :)
