How do I make a photo cd with slideshow?
Discussion in 'Desktop & Laptop Computers Forum' started by Timh, Dec 30, 2002.
  1. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    Santa brought me my first cd writer for Christmas :)
    I have burnt a photo cd using Nero VCD but when playing back on my dvd player i have to skip each photo, is there a way of making a burnt photo cd to show as a slide show, say every 5 seconds.
    I did make one with Nero using the slideshow funtion but it failed to recognise the disc in my dvd player :(
    Any idea's???
  2. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,163
    38
    Australia
    +18
    I think Nero will burn .jpgs as a Video CD with each frame being a chapter on the disk. Give it a try...
    Regards,
    Ian Guinan
  3. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    hi Ian
    I just gave it a go and it ended up showimg thumbnails on my TV it would not play them back :(
    I'm a bit of a newbie when it comes to burning disc's. Have you any idea how to do it correctly?
    Thanks for the help.
  4. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    I have now used Nero Express to make a VCD, it states it will playback photo's on most DVD players, I have made two, one with VCD menu enabled which gives me Thumbnails which will not playback, and also with VCd menu disabled where I get no menu but the photo's play OK but I have to press skip on each photo to view the next, this is a bit of a pain and surely there must be an easy way of doing it.
    VCD menu enabled plays OK on my PC.
    Tested on
    Toshiba Sd-510
    Sony DVP-335
    which both play cdr/rw discs.
    thanks
  5. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,163
    38
    Australia
    +18
    Sorry Tim..I haven't really had much of a play with this.
    I just burn my .jpgs to CD now and the player does a good job of slideshow and menu abilities (Denon 3800) so haven't had to learn how to do this.
    Sounds like you are making some progress now.
    Ian Guinan
  6. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    Thanks Ian
    I have just down loaded VCDEasy but its not that easy to use :confused: , it has a 16/9 option for widescreen tellies, I have managed to get a folder of photos ready for burning but I am having problems getting it to burn, Oh well off to read some more help files :(
    Not as easy as Nero :(
  7. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    :D :D :cool: I have now managed to burn a photo cd with auto slideshow using vcdeasy.
  8. Russell1
    Russell1
    You can set the pause between frames to whatever you want - it is originally set for "infinite", but if you highlight all the pictures in your compilation & click with right mouse button - go to Properties, change pause setting to seconds then type in whatever pause you want to add.
    HTH,
    Russ
  9. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    Thanks Russ, I will give it a go :)
    Damb...I forgot the Golden rule, always try the right click on the mouse.
