How do i make a 16.9 diy screen
Discussion in 'Projectors, Screens & Video Processors' started by dazap, Apr 16, 2005.
  1. dazap
    dazap
    Oct 21, 2004
    900
    shrewsbury
    +59
    can some one please give me any ideas on how i can do this i would like to make a 6 foot screen so i have seen that i could make it out of blackout meterial but really dont now how and also how do you then put your black lines around this. oplease forgive as i am a complete newbie to this :lease:
  2. homeagain
    homeagain
    Mar 24, 2004
    411
    Norfolk
    +9
  3. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
  4. nwhitta
    nwhitta
    Feb 1, 2005
    131
    +4
    Buy a 3mm sheet of expanded polyurethane (foamex). Cut it to size with a stanley knife. Screw it to the wall with four screws (white screw head covers make it look neat). Job done. :)
  5. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
    Is this serious ? Is the surface smooth ? Is this from a DIY store ?
    Ray
  6. nwhitta
    nwhitta
    Feb 1, 2005
    131
    +4
    Yes, it is serious. There are several threads discussing the merits of foamex. I don't know if it is available from your local DIY store but it can be ordered over the internet and the supplier will arrange delivery to your home. I got mine from Holbourne Industrial Plastics Ltd, who have a website at http://www.holbourne.co.uk/
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Foamex does sound intriguing.
    I'd be slightly wary of the hotspotting though, and I think it's not as clear cut as "hang the PJ from the ceiling and you won't see hot spots". I'd guess lots of aspects such as distance, height, lens shift, type of lens eg long throw/short throw may govern if you are unlucky enough to see the lamp glow from your ideal viewing position.
    Out of interest what's the going rate for an 8ftx4ft piece?
    ...PJ
  8. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
    http://www.dishley.co.uk/substr.html
    I've just e-mailed for the price of 8x4 and 10x5 in both 3mm and 5mm. Will post reply as soon as.
    Ray
    PS Are you following me PJ ? :D
  9. [Slip]
    [Slip]
    Jan 28, 2004
    184
    +3
    Hi Ray,
    Any news on those prices?
    Matt
  10. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
    No not yet. I phoned them as well and they promised to email me. Bloody useless :mad:
    Anyone else know where to try ?
  11. nwhitta
    nwhitta
    Feb 1, 2005
    131
    +4
    Price quote from Holbourne
    1 sheet Forex Foamex Foamed PVC Sheet, White - 96" x 48" x 3mm thick
    Price: £ 47.59 per sheet
    alternatively
    1 sheet Unbranded Foamed PVC Sheet, White - 96" x 48" x 3mm
    Price: £ 36.46 per sheet
    VAT (17.5%) plus delivery (£11) to be added to above prices. Larger sizes are also available.
  12. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
    Thanks. I'm looking for an 8ft screen which will need to be 54" high so I'll get a price for 10ftx5ft.
    Are you quite sure it does the job ? At £50 it's cheap if your right .
    Ray
  13. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,418
    Surrey. UK.
    +2,083
    I used plain 75mm x 18mm wood from B&Q and stretched/styapled blackout fabric over it. It cost less than £28 at the time (84" wide 16:9). I glued and screwed the frame together and you can't see the wood underneath. I've since bought some 1.2 gain material from www.ellie.co.uk and stretched that over the top when I bought a new pj.
    Pics in my link below.
    Gary.
  14. nwhitta
    nwhitta
    Feb 1, 2005
    131
    +4
    Foamex works very well. It is better than a white painted wall. The surface must be very similar to a commercial screen, but without the tendency to ripple as it is not a fabric. It is also fairly cheap. It may not be quite as cheap as black-out material stretched over a frame but it is much less hassle and probably better quality.
  15. dazap
    dazap
    Oct 21, 2004
    900
    shrewsbury
    +59
    ok guys thats great im gona go for blackout meteial its 3.99 a meter but now i need to no how to put the black borders on and wat size it should be
  16. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,418
    Surrey. UK.
    +2,083
    I didn't use black borders with mine, as the wall behind the screen is black carpet, but I'm sure there are plenty of others that have made them. A black border certainly fnishes a screen off nicely though.
    Gary.
